possibility to link LR out to 5-6/ 7-8/ 9-10 stereo mix on qu-pac
Hi.
in qu-pac the matrix 1-2 / 3-4/ are routable only to alt-out, aes, and usb.
but alt-out don’t need this, you can choose in alt-out routing menu’ the source…and you can assign what you want.
for supply the not present xlr matrix out in qu-.pac, you can add in next firmware the possibility to link LR out to 5-6/ 7-8/ 9-10 stereo mix.
in this way, we can have the same mix in different mix out but with separate volume,eq…a good alternative for qu pac user.
thanks in advance.
It might even be possible to have the outputs be a bit more patch able, but that rather breaks the labelling…
I’d like the local outputs to be patchable too.
The labelling issue would really confuse matters, regardless of whether it’s technically possible.
Hmm, the group of “Mix Outputs” are labelled 1…10. Making them assignable isn’t any more confusing than assignable inputs, dSnake ports or QuDrive streams. Just stick a small black tape over the letters “Mix” and everything is fine. :wink:
