Possible?: Channel routed to monitor mix Pre EQ?
If so, I’m not finding where to change it.
Keith: The community’s Search feature needs to be made forum specific, instead of showing results from them all.
Select your Aux master. Go to the “Routing” button / page. At the top on the tap the ‘Aux Snd’ area that has the little gear on it. This will open a window where you can select the pick point for that mix.
@TimmyP
The different options and where to find them are detailed here - https://www.allen-heath.com/media/SQ_ReferenceGuide_V1_5_0.pdf#page=40&zoom=auto,-361,573
You can check the block diagrams at the end of the reference guide to better understand the signal flow (and possible flow).
A basic version of the SQ signal flow can also be found here - https://support.allen-heath.com/hc/en-gb/articles/4402940459537-SQ-Basic-Signal-Path-Diagrams-Input-Group-LR-Aux-Matrix
Cheers,
Scott: Ah! Thank you.
Keith: A search of the manual for Pre does not bring this feature up in the results.
