Unless I am missing something, I cannot achieve post-fade metering on input channels from the metering page/custom metering pages. I’ve seen a post from the iLive forum from several years back with a similar request, but no mention anywhere else. All of the pre-fade options make sense setting up for shows, but come showtime it’s much easier to mix post-fade for balancing many inputs.
You have to push the Setup button.
Loloverde-
Per the firmware documentation:
Hold down Setup and touch anywhere in the Inputs or Mix meter tab to set the associated source point. This will affect the Surface LED meters too. Options available for Inputs are Post Trim, Post Gate/PEQ, Post Compressor, Post Delay. Options available for Mixes are Post Trim, Post Insert Return, Post PEQ, Post GEQ, Post Compressor, Post Fader.
Post Fader on inputs is NOT an option through v1.8x.
+1 for Post Fader input metering. I’ve used consoles in the past that had that option, and I found it to be useful at times.
+1
One of the first things I noticed when I got my dLive. Meant to start a feature request. Thanks!
Before I had my iLives I had a Roland VM-7200 board that had Post-Fade Input display and I found it very useful for checking the balance on things like backup vocals. I’m surprised that boards as sophisticated as the iLive and dLive don’t have this option as it’s probably just a few more lines of code in the OS.
-Mark
In a hectic festival situation it happened to me that one channel was distorted even though the level meter didn’t show any overload.
The answer to the riddle:
It was a Midas XL3 console whose level meter showed the signal strength at the “PreFade” position. The compressor in the insert was very strongly adjusted by predecessors, so that the signal was strongly limited. But since the insert was before the level meter, I didn’t realize at first glance that the preamp was too high.
From this experience I like consoles that show me the channel levels post-preamp, i.e. pre-everything
So if there should ever be the possibility to display the levels “PostFade” as well, the option “Post-Preamp” should be kept. Please.
Another explanation of my thinking:
In live mode, I have my levels under control during the show so that I don’t need a post-fade display. I can easily check the true volume ratios with my ears.
What I liked to check again and again are the levels that the musicians give me. Some musicians like to change these levels, sometimes even in critical areas. Especially musicians you don’t know yet can surprise you during the show. In my experience, the keyboard players are the most critical.
That’s why I always put the Meters on post-preamp.
the output meters, on the other hand, I like to set to post-fade
strange discussion… if input metering is set to post fader, you can’t see a signal wich is down from a DCA…
even if it is going nuts on the pre fader monitors
very dangerous…
Definitely agree about pre-fader for the on-surface channel strip led meters. But for custom User Meter UI Panels, we should have the input post-fade option.
In the other brands implementations of this, the clip/peak lights still work as expected regardless of where the metering is set.
This is one place where I think the SQ is flawed. My old Presonus board allowed pre or post fader metering with the push of one, clearly labeled and lit up, button. We can’t be without pre-fader metering but post-fader metering is still very useful. I would love to see this with a flashing softkey option that could let us know we are in post-fader mode.
I would also love to see a post HA but pre Trim meter option. When using multiple dLive surfaces it would be very helpful to know what’s happening at the split point.
Any movement on this issue?
