pre-amp noise
Hi again, last weekend in the last miutes of the show someting extrain happened, in the socket B7 appaers some noise like ground problem in the line, it was a keyboard but when i turn off the channel it still been present and the worse it was audible, I turn off all the gain and turn on the Pad but it seems like no take effect over the noise, any idea???
Comfortably numb
Hi Noeme,
Does the problem still remain on the same socket B7? if so sounds like it could possibly be a hardware fault with that socket. Does the same noise appear when you assign another DSP channel to the socket B7?
I recommend you contact your local distributor to see if they can assist you in resolving the issue. if not pplease contact A&H technical Support
https://www.allen-heath.com/uk/support/Pages/support.aspx
Regards
Sam A&H
