pre-defined library
as a new member (Germany) in GLD-Forum I have e few questions before ordering a GLD-80 + GLD-AR2412:
1.) is it possible to have access to a pre-defined library for various instruments (drum, git, bass, keyb, tromb, trump, sax, voc)? This would make it easier for me setting up the system and then only doing small adjustments.
2.) would a 50 meter Klotz hybrid (2 x cat5, 1 x 230V) work with a GLD-80 or is it saver to have the lines (cat5 + 230V) separated ?
Thanks for your help
Hi!
  1. There is no predefinded (eq / compressor) library available for the GLD. You can make it yourself and build your own…
  2. Klotz hybrid is a good cable. Will work like a charm :smiley:
regards,
Pascal
GLD80 :smiley:
You have access to a library, but there is nothing in it until you make the settings.
The items in the FX rack do have lots of library presets.
Chris
thanls Chris and Pascal for your help
I use a 50m Bespeco CAT6 cable with RJ45 connectors without a problem.
For the library the best thing to do is make your own preset!
bye
Luca
