Is there any way to make slight setting to delay for the channel not in meters but in centimeters.
I wanted to set up delay between snare and overhead mic and it was impossible to get it right roughly. For example to around 2 meters for drums mics. The range is from 0 to 116m.
It goes with jumps from 0 - 0,43m - 0,87m - 1,3m…etc its already hard to set up them only with this, its impossible to be more precise. With miliseconds its the same.
I have a mouse which can change the sensetivity. The minimum increment is 43cm. When I hold the ctrl button it is 5cm. It does not change with a different mouse setting.
I tried different mices, some of the were better but keeping the same amount (e.g. 0,7) and then releasing the mouse is difficult because it can still skip by extreme amount.
