Problem Ganging LR
I think I’ve detected a buggette when ganing the LR fader function.
This seems to disrupt the proper working of routing and panning when routing LR to a stereo matrix.
Regards,
Marc
Make sure Routing is de-selected in the ganging attributes for main L&R possibly?
I think the Default is no ganging of the routing and the faders.
By ganging the Routing of main L&R was the only way I could make it do funny things.
Hope I am right, I am sure Carey will have chapter and verse on this.
Mr.B
When you set Ganging for channels or mixes make sure you check and set the Attributes too. Gang only the parameters you need to link. In the case of the LR master you would typically want to link the EQ and dynamics processing but not necessarily the faders and mutes, nor the Routing which include the assignments and levels from the masters to the matrix. Unlike the input channels the LR ganging does not have a separate Pan attribute so pan gets linked too when you select Routing. This is something I will review with the team here.
Regards,
Carey
