hi Guys
am having problem with QU-16 while recording or streaming any audio from a windows 7 pc
using a safe buffer size 1024
during recording i’m having this static or somekind of distortion appear for about 15sec and then back to normal and the worst part is the distortion is recorded together with the source
click this link to listen to that problem
https://soundcloud.com/studiohive/sets/qu-16-problem/s-PAOSV
the pc spec that i’m using is amd fx8 8320 8gb ram
os windows 7 ultimate 64bit
DAW used cubase 5.1.1
I had a similar-sounding problem (Win8.1, Sonar Producer). After about 10 minutes of recording directly via USB into Sonar, the sound became progressively distorted with added weird sounds and in the end became useless - and was present on the recording. Somewhat strangely I found changing from the onboard sound card to a Soundblaster PCI card did the trick. It’s not obvious why this should be unless there was some weird contention over memory on the pc’s main board. Worth a try anyway.
Hie Chris … thanks for replying … appreciate it …i will try to get a pci soundblaster to give it a try
if anyone have any other solution do post it up … looking for more solution to try to solve it up
thanks
Hi Seikan, the card I bought and am happy with is: Sound Blaster Z PCIe (Amazon £60UKP). Good luck! Chris
