I’ve loaded up 1.82 and I’m having problems scrolling using the scroll bars in the Library Manager. If I tap multiple times above or below I can get it to scroll pages but its very stubborn. The slider is changing colors when I tap so it appears to see the taps but does not scroll.
Anyone else have enough presets to try this?
Hi dburris
when the scroll bar lights up orange that means that it has connected to the touch screen rotary encoder (which will also have lit up), which can then be turned to scroll up or down.
Hope this helps
Regards
Sam A&H
quote:
Originally posted by Stealth
Hi dburris
Hope this helps
Regards
Sam A&H
Yes, that works. I thought I should also be able to scroll using the touch screen.
