Noticed another minor problem with Multi Select on the CQ-20B, from the Android app:
I can’t include both Stereo channels at the same time. As soon as I select one of them, the other one gets unselected again.
Also, performing the Multi Select seems much more cumbersome than what is possible on the CQ-18T. There you can just sweep across the channels to do the selection, but in the Android app you need to individually and explicitly press every channel to build your selection, which considerably slows down the selection process.
Here again, a question of whether and when the Mixing app functionality and behaviour can be brought up to parity with what is on the built-in ‘in-built’
screens of the CQ-18T?
