Problem with scenes after update 1.4.1
Hello !!
I found the same problem as in firmware version 1.4 …
when you change from scene to scene the gain of channel 1 does not change … it does it only in the local port … in the IO DANTE port … it works perfectly … thanks a lot for the availability …
hello! … solved … I reset the mixer … it works !! … thanks a lot !!
