The problems in GLD, I have version 1,02. I have a problem when changing the “template” when change to another one, I lose the kept scenes.
I don’t know what happened this?
i don’t run my GLD well?
Greetings
Greetings
Hi Rorikx
Templates are Shows. All scene information is stored within a show file. If you change show then all the current scenes will be overidden by the scenes stored in the new show you recall.
You should always save your current show before recalling another so you do not loose any settings you may have changed since last saving.
I hope that helps / makes sense
Regards
Sam A&H
Thanks for reply.
The GLD works fine, its only fail me
Sorry
