After updating my CQ-12T to firmware V1.2.0 when I solo a channel to listen in my headphones it’s soloing the channel Post Fader instead of Pre-Fader, is there a setting that changed that I am unaware of. Before this update I was able to solo a channel and listen to it even if the fader was pulled down or the channel was muted.
Input channels should be Pre Fade Listen and Output channels should be Post Fade Listen
If this is not what you’re getting, please try storing your settings as a show to a USB drive, then carrying out a hard/factory reset before testing again.
If loading your show back onto the unit reproduces the issue, please send us a copy of the show by submitting a ticket through support.allen-heath.com or by emailing support@allen-heath.com so we can look into this further with you.
I think in those cases you were listening to an input and are now probably doing so on an output (where PreFL is not possible).
