Promising Wireless router
Does anybody have experience with this one?
DIR-655 - Wireless N Gigabit-router
IDR32
Dante card
Macbook pro 17
Ipad2 + mixpad
Aiport express
I tried like 4 different Wireless Routers. And ended up ( after A&H published the list) with the D-Link DIR-815. They all worked well in home / test environment. Some better with multicast then others. But in the end when it came to live venue situation, they all started loosing connection constantly. During soundcheck everything worked fine, but the moment the people get in, and the real deal begins, the problems start.
I think this is for the main part caused by all the people having there 2,4Ghz Mobile and today has there Wifi / Bluetooth … turned on.
The moment I switched to the D-Links 5Ghz band, all these problems disappeared. I cannot say that the connection does not drop anymore, but its 10 times more stable is in the 2,4 Ghz band.
As said I tried 4 routers out of the A&H shortlist. From that list the D-Link DIR-815 is for me absolutly the winner
Best Regards,
Rene
T112&IDR48
Dante
Ipad
MBpro
Nothing is completly true, and even that’s not true.
Same here,
5Ghz 811,a is the way to go [:smile: ]
Lieven
T112/IDR48/R72/IDR16/xDR16/IPad1
Save a tree, eat a beaver
Another new one hit the market. I sent an email to tech support and received a response this morning.
Dear Sir/Madam:
Thank you very much for your email requesting information about our product
The TL-WR2543ND also support multicast streams IGMP.
Hope these would do help you and any other question would be highly welcomed.
To get technical support more quickly, please go to https://www.tp-link.com/en/support/faq.aspx?type=2
Best Regards
Nacy.mo
Technical Support Engineer
TP-LINK TECHNOLOGIES CO., LTD.
Tel: +1 866 225-8139
+86 755-2650-4400
E-mail:Nacy.mo@tp-link.com
Website: Support | TP-Link
Original Message
From: Christopher Johnson [mailto:ceejay64@comcast.net]
Sent: 2011#24180;9#26376;28#26085; 11:31
To: support.usa@tp-link.com
Subject: New TL-WR2543ND question on IGMP multicast streams.
Good day, and thank you in advance for reading.
I am a current owner of the WR1043ND.  This router does support multicast
streams IGMP.  Since this only uses the 2.4 GHZ band, I am interested in
your new model as it works in the 5GHZ band.
My question is, will the new WR2543ND support IGMP multicast streams?
In particular, a group address of 239.0.1.1?
I could not find a setting in the user guide on your site for multicast
streams for the new router, but the WR1043ND does not have it either.  There
was a firmware upgrade to support it at a later time.
Thank you for your consideration.
Sincerely,
Chris Johnson
Oswego, IL
CRJ
Oswego, IL
T112 & iDR48
Sony F 1.73GHZ I7 8 Core
Win 7 Pro 500GB HD 8G RAM
TP-Link WR1043ND & Airport Express
IDR32
Dante card
Macbook pro 17
Ipad2 + mixpad
Aiport express
I’ve had one laying around for a while that I just set up to try out with the rack and computers. Had it running with the rack, a desktop, X61 tablet and iPad2. Used it with Multicast enabled and MAC filtering and it seemed to work good as far as the metering went. Had everything in the basement but wandered upstairs with the iPad to try it and it worked well when I was up there. I hit a dead spot on the way back down as the iPad lost the connection but it reconnected fine.
I’m finding the iPad wireless not quite as robust as the tablet but I haven’t tried it in a larger open space yet. I think it was getting better signal running on N on the D-link than G on the Linksys router I’ve been using. The Tablet is G only and still seems to get a better signal though. If you have a DIR 655 available you might give it a try, if not maybe the DR815 would be better with the 5 Ghz as several have mentioned.
P.S. Anyone know where the iDR racks are supposed to have their MAC address listed? I couldn’t find it on mine and had to come up with a command line program called Arp to get the MAC to enter in the router. I’ve got it now but was tearing my hair out trying to find it.
P.P.S. Well I did finally manage to overload the DIR 655. Running Editor on the Desktop and Tablet, Mixpad and Jump Desktop into the desktop from the iPad. the meters starting freezing randomly in the two Editors and MixPad. I still had control from everything, just the meters were going AWOL. So either I was brute force overloading the wireless or the Multicast on this router isn’t up to standards.</font id=“red”>
Scott
iDR 32
iDR D-Out
MMO
Lenova T61, M90, iPad2N
If anyone is interested: i have tried the netgear WNDR3700 with multicast “on” - and everything works fine.
Are you still happy with WNDR3700 ?
Purchased and tested the TP-LINK TL-WDR4300 N750 Wireless Dual Band Gigabit Router. IGMP proxy supported.
Replacing my TL-WR1043ND which does not work in the 5GHZ spectrum.
Multicast on my rig is always turned on whether I am using the T112, or just a laptop and iPad.
Mixed a show with just the laptop, and used iPad throughout a three hour show. Laptop also connected wirelessly. I had to restart the iPad once due to distance, approx 300 feet.
Maybe I am just lucky, but my connection issues using the old router have always been related to wireless traffic on the 2.4GHZ band.
The TL-WDR4300 is under 90.00 in the US.
CRJ
Oswego, IL
T112 & iDR48
quote:
Yes i am. Working without problems very well.
