Hi all.
Short version of my question (novel-length addendum below):
I’m about to buy either a Qu-24 or a Soundcraft Si Impact. I’ve watched a lot of YouTube footage and read both systems’ user guides. I’m leaning towards the Qu. To help me decide, I’d love some real (latest-firmware) users’ feedback on a few issues I’m still unclear on, where I’ve been having specific problems with my current rig:
-When recalling a scene from memory during a performance, does the Qu mute its mix outs and/or digital recording channel outputs? If so, for how long?
-How much latency is there between hitting the “Load” button and it taking effect on the mix?
-How long does the control surface take to update itself and let you resume mixing after the change is applied?
-As opposed to Scenes, does applying a ‘fat channel’ preset (one with a big EQ change, in particular) to an input in mid-performance glitch that channel audibly?
During rehearsals (and afterwards, when working on mix scenes), I need to be able to conveniently/rapidly switch between recording/mixing/monitoring 8-12 tracks of live vocals, and playing them back.
My regular gigs are vocal acts. My ‘live’ routing would typically be analog mic inputs on ch’s 1-12, with a couple of outboard FX channels fed by a couple of stereo Aux mixes and returned to inputs, along with using the internal FX active. The ‘playback’ routing would be those (pre-fader, dry recorded) mic channels set to USB, with the internal and external FX still running live (meaning 2-4 channels of external FX would still be Analog).
-If I’m using a USB-connected DAW to do the recording/playback, is it going to be particularly awkward to switch between the two sets of digital input routings described above? Can I do it with a scene, or is it in practice easy to access/poke the required buttons on the the touchscreen?
-Am I missing any ‘gotchas’ about the USB-DAW routing that will keep me from doing this in-place? I’m typically looking to use the playback as something of a virtual soundcheck, so I need the playback channels to be mapped to the same channels as my live inputs.
Long(er)-winded explanation of why I’d like to know…
I’ve spent the last few months in a failed attempt to get to know & like my Presonus CS18ai controls surface / RM16ai mixer combo.
The touch-sensitive faders on the CS18ai make it very appealing as a DAW control surface, but for me at least, it has proven to be less than ideal for live use. It is causing headaches in several of the areas I was asking about above.
I am about to trade it for either a Qu-24/AB168, or a Soundcraft SI Impact and one of their smaller stage boxes.
Both systems look like they’d address my main concerns with my Presonus re: the control surface’s workflow. Both seem to also have pretty well-thought out features for Scene Recall, with appropriate parameter-based an filtering and channel-based “Safe-ing”.
Q-Drive and the A&H IPad software look like a tie-breaker in favor of the Qu24.
However, I do make heavy use of scenes, both with my regular acts’ musical gigs, and a few times a year in amateur theatrical productions. I’d like to recall scenes in mid-performance if possible, and if not, in very tight spaces (time-wise) between songs/stage cues.
I really want to make sure my new board provides a satisfying experience in this area.
My old StudioLive SL16.4.2 board had near-instant scene recall, but muted audio for a couple of hundred milliseconds while doing so. My new RM/CS “Ai” based setup doesn’t mute the audio (very helpful!), but takes a while (seems like something between 500msec and 1 second) to apply the change, and (no kidding) up to 4 or 5 seconds after that to actually update the control surface. During that window, you can’t mix. That ‘blackout periond’ is pretty annoying/embarrassing if you pull up the next song’s scene (perhaps with a heavy reverb on the lead vocalist)… and that vocalist is trying to banter with the audience. Also totally unworkable in the middle of a musical theater performance.
I’d really like to make a good decision this time around; any input on the above would be much appreciated, along with any random observations that might distinguish the Qu vs the SoundCraft.
Tony
