Is there a way I can route ST1 to channels 15 and 16 on my Qu-16? I have my laptop connected to my Qu-16 via USB, and I want to be able to control laptop music levels using CH15-16 faders (linked) so I don’t have to keep swapping layers, as my mics are in CH1-12.
Nope, but as an alternative you could add the ST1 fader to whichever custom layer you want ?
Good luck !
Giga
If using an iPad you have three custom layers. On the QU16 surface you can create a custom layer, go to the set up menu, control, custom layer.
To access the custom layer you press the two layer buttons at the same time.
Do that you can assign the channels you need to be in the same layer.
Thanks. Assigning channels in the custom layer, including ST1 to 16, gives me the single-layer control I’m looking for.
