QU-16: Delay in reverb with internal effects?
I’m using a QU-16 for a vocal group. I want to run a delay into a reverb in series: the signal goes through a delay first, and the delay output feeds the reverb. The result is a reverb that “blooms” at a rhythmic moment — in my case around 350ms.
Is this possible internally on the QU-16, and if so, how? Or do I need an external delay unit to make this work?
Send the delay return in the reverb.
Can you please specify how?
Thanks you =advance!
The delay return is another input channel. It works like all other inputs, except that the signal comes from the FX engine. Press the mix for the reverb and move the fader from the FX return upwards. Make sure the return channel is on, and the fader is up on the main mix too.
So no routing needed? And use the fader under the SEL button?
Same way you would send any channel to your effect.
You send the delay return to your reverb using the same technique.
It is routing what we are doing here. At least you can review it inside the routing screen.
