I normally set the various mix mutes to the soft keys. I can give them names etc., shut down using the correct procedure and turn off. If I turn back on, none of the groups/names have been saved. I have no ‘safes’ or global filters’ enabled. I also notice that my mix graphic eqs are reset to flat lines.
The problem will occur if I turn back on and select the same scene - or swap to another scene and then return.
I’m guessing someone will say to do a hard reset. If I back everything up on to a USB stick, would I be safe restoring the saved scenes, or will I be re-introducing the fault? I only have about 10 scenes - all with the same band - so not a huge issue to start from scratch.
TIA
Dick
