This board has 10 Mix outputs with 5/6, 7/8, 9/10 being stereo pairs or use as mono. I am outputing these into a Behringer converter for in ears and need additional outs. While I can use mono…this would basically reduce 10 total outputs to 7 mono. Any chance these stereo outs can be switched to multi-mono so I can have 10 mono outputs?
As far as I know, the QU-16 only has the 7 non-expandable mixes.
Only with the Qu-32, Qu-Pac, and Qu-SB could you use 3 groups as mixes to reach the required 10 separate mixes.
As mentioned the QU16 only has the total of seven mixed and the stereo mixes can not be split.
…however with some creative panning of the stereo mix sends you could kind of cheat two mono mixes out of a stereo mixes, cumbersome yes but doable.
