Qu-16 Tcp Get Meter Data Troubleshooting
I’m new here, I’m having a bit of a hard time interpreting the data sent back from the Qu-16 model. The protocol is 1.82 and after looking at the pdf it mentions how the data is encoded/decoded. If I understand correctly:
-Every 8 bytes must be unpacked into 7 bytes.
-2 bytes (16 unsigned bits) are used to decode a single float (db).
My questions:
-The meter data is in dB, but the meter is in dBu’s, am I missing something here? db dBu conversions is impossible if I’m understood correctly
-The amount of data as you’ll see in the log varies everytime, why is this? If the transmission order is correct I don’t see how this would make any sense.
-How do I get the db for the meter? (picture attached)
I attached a more technical detailed log of what is happening. The audio is a sample of constant volume.
Here the technical log. (Mediafire) (4.25mb)
Any help is appreciated. Maybe I missed another forum topic regarding this…
The protocol I’m refering to: https://www.allen-heath.com/media/Qu-MIDI-Protocol-V1.82.pdf
Austin
