QU 16 - with DSnake Ar 824
Hello
I am using Qu 16 . mixer - and now i like to try a dsnake and Ar824 Stagebox
Now my Problem, my Master fader ist out of work - if i use Dsnake -
Master L + R is now on - Mix1 +Mix 2 on Chanel 10+11 (where ist printet Mix1+2 )
How can i do Routing - this back to Master fader ???
Thanks for Help
Check page 13:
https://www.allen-heath.com/media/Qu-Mixer-User-Guide-AP9372_1.pdf
Main L&R are on the Channel 11 and 12 on a AR2412 or on 3+4 on a AR84!
Change the routing isn’t possible with the Qu-16!
I thought the source and output are all configurable with either of the AR stage boxes. Go to the channel and select the fn key bottom left of touch screen and there you can map from any in or out of stage box.
Hello OK
Is it now -Possible to work with dsnake and - an operating - Master ???
is Routing from mix1 +2 ( chanel 11+12 ) posible back to the Hardware -Master ???
or is qu16 and Dsnake - not configure the - Hardware master —
Using - 11 +12 ( Mix 1 + Mix2 - as Master by working with dsnake - isnt - very lovely –
I am not Happy - if Hardware master doesn-t work-
Thanks for help
again: RTFM!
Check page 13:
So you don’t need to USe Mix1 and Mix2 for Main L&R Just Plug the PA in to the correct Channels of the AR Rack!
