Qu-24 and Qu-16 as one console
Have you test to see if, with the new firmware releases, if these can be linking through Ethernet Cable? I know you can now digitally link the QU and SQ series…thanks
In April we may have a work for a symphony orchestra. That production needs 48 channels and more groups, so we are going to use two QU-24 for inputs and one QU-16 for groups. The whole console will be just 170 cm wide this way. (48ch analog consoles are often 2 meters wide or more.) Stereo MIXes (5-6, 7-8, 9-10) and main L/R outputs on both QU-24 will be the group outputs of different kind of strings, brasses, flutes, oboes, percussion, etc. Those 16 channels (8 stereo groups) will be controlled by QU-16.
So that will be a 48 mono and 6 stereo inputs setup.
I haven’t tested through ethernet cable. We use Linksys 1Gbps wifi router for the connection.
I’m interested in learning about the ethernet link between mixer. But does that only works between a Qu and a Sq? Or can I do 2 Qu mixers together?
Sent from my ONEPLUS A5010 using Tapatalk
My QU-24 and 16 are connected to the same router, but as I see, we can not make a master/slave connection between the two consoles. I gess there is no such menu on these softwares.
Many people ask me about BCF2000 using as a group controller with QU mixers. I worked with analog systems from 1981 to 2015, so nowadays we combine the analog and digital connections. I can not connect directly a BCF controller to the QU units, but I can get the groups together (from not only one QU mixer) on a digital submixer, that I can control by BCF and I can see all functions on it’s softwares. Last week we used this system…
Hi Dave!
I use the Behringer X Air X18 mixer, because it’s so simply compatible with BCF2000 that you need only to plug the MIDI Din Tx and Rx cables and they work together perfectly without any setup.
The Lan of the X18 is connected to a Gigabit router, so I can use the X Air Edit software on a MacBook, connected by Lan, and the X Air android app on wifi. (see on the picture)
All of the QU Mix outputs are plugged into the X18 by XLR cables.
The all system is very simple and stabile.
