QU-32 & ME-1: Can't get signal if fader at FOH is down
We recently purchased a ME-1 unit for our drummer and are having trouble figuring out how to get signal to the unit if the fader is down or off at FOH. For example, we have a talkback mic and a click track on separate channels. These are obviously down/off in FOH, but our drummer needs to hear it. Working off of the QU-32. Any help?
Thanks in advance!
Hi Jeremy,
The ME system uses the direct outputs on Qu and follow the Global Direct Out settings. It sounds like you have follow fader and follow mute enabled.
To change that, select an input channel and go to Routing. Here you can select the direct out source, but also make sure Follow Fader and Follow Mute are off.
Alex
