QU-32 Mute button
Hi Thomas,
Unfortunately not as I’ve not used Cubase for this task. Hopefully you find your answer on the Cubase forum.
Alex
Hi Alex,
thanks to your great information about MIDI messages I could solve this issue using Bome MIDI translator app.
I think there’s no other way because you can’t change Cubase’ standard outgoing MIDI Messages of Generic Controller, and so they won’t fit QU-16’s needs without a translator app (for Mute & Solo Buttons).
In Detail:
Mute & Solo messages are routed through Bome MIDI translator that translates them to be understandable for QU-16.
All other channel messages (Fader, Pan, EQ) are routed directly to QU-16.
It’s a Little bit tricky and Needs some time to find out the correct Translation rules, if you (or somebody else in this forum having the same problem) are interested in them it would be a pleasure for me to provide it.
Again thanks a lot!
Thomas
Hi Thomas,
I’m pleased to hear you found a solution!
Hopefully other users looking to do the same thing can make use of your work.
Thanks! Alex
