The soundboard records at a decent level on output channels 31 and 32 to a CD writer. However, when recording directly to the USB device on the Qu-Drive, the sound levels are so low it’s almost impossible to bring them up- even with other software.
I really need step-by-step instructions for how to change the levels for the USB recordings. I attempted to change the settings using instructions from the manual, but I couldn’t find things that it mentioned- and when I was on certain screens, the manual didn’t quite match the displays.
I DO understand that the USB drive records at 24-bit, but I don’t have the software to convert to 16-bit and I’m not the person that actually adjusts and uploads/burns (CDs of) files. So, I have GOT to fix the problem from the sound board.
I really appreciate your help!
Also, if there’s a drag-and-drop version of the software to convert from 24-bit to 16-bit that you’d recommend, then I’d appreciate a link or a program name.
Thanks!!!
