Hello
Anyone able to use qu series with protools 9 for windows?
It seems not compatible PT9 under windows with QU series,
Pls advise
Hello
Pls advise
I am using PT 12.4 with Windows 7, but there should not be a big difference as far as setup and I/O is concerned. Here are some things to check/try.
I have just started using my QU 16 as a front end interface for Pro Tools, but everything seems to be working OK for now once I made these changes.
Hope this helps.
ok 19 frets, I need to sit and check
Many thanks (y)
…and don’t forget the Qu only operates at 48kHz.
