No doubt David will answer this himself, but I’ve been looking, and it’s got some good enough stuff that I’m considering getting an Android device to run it.
With Pre you apparently get Popgroups, Unlimited DCA, the eq visible on channel strips, and a timeline for gates & comps.
My question for David, am I correct that I could run this app and one Qu-Pad app at the same time, as I totally forgot to test this when I borrowed a tablet the other day.
does seem to disconnect every few minutes, but maybe I’m not doing something correctly.
Hm usualy it should keep the connection alive all the time. Might be a bad wifi signal. I plan to change the networking stack so it just reconnects in the background automatically.
What does the paid version add? I plan on purchasing it, just because I’m so grateful, but was wondering what it would gain.
A comparison table can be found here:
https://bugs.dev-core.org/w/ms/qu/pro_free/
Note: The next update will also add customizable UI and USB midi support which is also only available in the pro version.
Yes you can It’s possible to use 1 Android und 2 iPads at the same time.
I’ll be looking forward to the update, I just left it disconnected and I could control the board anyways, but I couldn’t see any level meter feed back which was no bid deal at the time. With it reconnecting in the background without a warning popup it should work much better.
The app saves me buying a new Ipad now that version 1.8 no longer works on the original Ipad.
Hello Dave great app. I used it tonight for practice with our band. Set up the custom layers just for what I needed. Actually like it better than the iPad app. Very responsive and really well thought out. Only thing that would stop me from using it live is the lack of fx parameters. Is there a delay tempo tap button coming as this is really a necessity. Btw I purchased the pro version and I’m using a qu 24 and ar2412.
That sounds great. I’m already using an IPAD Air2 but I’m thinking about an Android tablet with a bigger screen and this app. The IPad Pro is to expensive.
Do you have any recommendations for an Android tablet with a bigger screen?
I’m using a Galaxy Note Pro (12,2 inch) and am very happy with it. I also use it for reading scores during gigs, and love the S-Pen feature as it gives more precise control when writing, drawing or using a complex UI such as the Mixing Station.
Mixing station Qu works extremely well with my Galaxy Note, even though I have a customized CyanogenMod ROM installed on the tablet. If 12,2 inches is enough for you, I can recommend that.
Thanks, siesta.
Today I tried the app with a galaxy note. Unfortunately it was only 10 inch. But the mixing station app is great, really really good. I love several features.
The only point is that the battery of the IPad is much better
Read further that you have this available at Google Play Store, so I
downloaded it and checking it out…
Thanks for your hard work!
UPDATE: Wow! beautiful app!! I’ve only been playing with it in offline mode,
but I’m am thoroughly impressed with the responsive and intuitiveness of it!!
I’m currently moving and only have internet access via phone so sorry for my slow response time.
I am working on a 1.9 version. But the current one should work fine with 1.9, just ignore the fwarning message.
Known issues with this method are: Tap buttons aare not blinking.
