Is anyone working with this as yet?
I’m trying to get it working at the moment, and could do with some help - but I don’t want to keep bugging the author…
Maybe other people on here would be in a place to help me work out what is wrong…
Pro edition installed:
- BCF2000 plugged in via USB OTG cable.
- Menu → Setup → Midi → Add Controller
Select Fader
Select Type CC
Channel 1
Fn and Value I ‘learn’
Add an action:
Active, current layer
It fills in - Offset 0, Main, Fader (Use SOF)
The fader moving then jumps the level of Ch1 to -9dB, and it drops to -inf when it stops… Actually any fader does the same - Ch1 on all…
So there is some comms, but not the correct info.
OK - found the problem (after googling for diagnostics)
The BCF2k was in HUI mode, I guessed (from the instructions to enable HUI mode) that powering up with the top left button pressed would revert to a more compatible mode.
Faders work just fine now. I need to decide whether to try it this w/e
Rotary controls not doing what I expect, I shall have to play with more options - and of course I shall have to set up some of the other buttons as well.
Looks like a really nice ‘monitor console’ if I can set it up right (I hope the custom buttons can change the mix I’m looking at - I don’t need mute/PAFL on each channel, but using each one as a ‘fixed mix’ will work for a 7 piece band (and FOH as 8)
