QU-Control app and Scene Recall
Anyone using a QU mixer in a multipurpose room scenario? I was planning to use the QU-Control app and set it up to facilitate one-touch audio setup for the room based on a set of predefined setups built as scenes.
The QU-Control app page on the AH website boasts the ability to do scene recall, but when I went to setup the app, scene recall was not one of the options. Anyone have any insight? I hope they were not referring to the use of soft keys, as the QU-16 only has 4.
It’s a soft key program function. I’ve used the QU Pac on quite a few installs
with Qu Control on select people’s phones and iPads.
I’ve never set up a QU16 with QU Control using the QU Pad app does it give you more
than the four soft keys that are on the surface.
I find 3 aps at https://www.allen-heath.com/series/qu-series-apps/
Which one are you using?
Our music director uses the Ipad version. Just got it but he indicated he could access the main QU32 and operate it from the IPad. That would seem as if he could recall scenes that way.
And down a ways on this page: https://www.allen-heath.com/ahproducts/qu-pad/
it says you can do scenes.
no, it doesn’t
QU-control.
the setup isn’t for me, it’s for the people don’t know anything and don’t want to know anything. one-touch settings that just work…I need more than four, though.
@cbcmedia
looks like it says so to me
could not cut and paste image
but here is a cut and paste of the text on that link
FEATURE SUMMARY
Version 1.9 now provides full control including mixing and setup functions.
Live mixing and setup functions available include:
Fader levels, mutes, pans, PAFL
Mix/FX sends, channel assign, Pre/Post routing
Local/Remote Preamp/USB source selection
Preamp Gain, Pad, Polarity, 48V and linking.
Ducker/insert select
HPF, Gate, PEQ, GEQ, Comp, Delay
Custom Channel Naming
Custom strips for personalised channel layout
Full FX parameters, including Tap Tempo
Mute Groups and DCAs
Talkback, SigGen assign
Network and MIDI control
USB data and device management
Full metering including Mute/PAFL status and RTA
User Permissions and Passwords
Qu-Drive USB record/playback control
Scene and recall filter/safes management <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<-------------------------------------
Total Local/Remote/Monitor and USB I/O patching
Remote Shutdown
There are 15 soft keys available, however, only 4 of the appear on the desk itself as physical buttons.
I no longer have a Qu-16, and can’t quite remember how you access 5 - 15 on the desk itself, but I do know they are all easily available in the Qu-Pad app.
So you can set up, up to 15 scene recalls on soft keys, then place them where you want in the Qu Control app.
markPAman, this is perfect, thnx. the extra soft keys are in fact ONLY visible/programmable via the QU-Pad app. I’ll assign them there, then setup the QU-Control app for dumbed-down usage.
volunteer, I am aware of the QU-Pad app and its breadth of control, my post was concerning usage of the QU-Control app which advertises scene recall, but doesn’t directly offer it…only via pre-programmed soft-keys. I guess that’s the route I have to go. The QU-Pad app IS essential, though, for access to the “hidden” extra softkeys on the QU-16 desk.
@cbcmedia
sorry. I saw 3 Qu control aps on the AH website.
I did not see any scenes for the other aps.
This is the claim for your Qu-control at the AH link for qucontrol
https://www.allen-heath. com/ahproducts/qu-control/
SCENES ARE NOT LISTED
Features
List of parameters assignable to Qu-Control:
Input Faders
LR On/Off buttons
LR On/Off Radio buttons
Master Faders
Input Mutes
Master Mutes
Mute Groups
Send Levels
Send On/Off buttons
Send On/Off Radio buttons
Group Send Levels
Group On/Off buttons
Group On/Off Radio buttons
Matrix Send Levels
Matrix Send On/Off buttons
Matrix Send On/Off Radio buttons
Softkeys
Volunteer,
“Qu-Control offers simple configuration of up to five screens with up to 15 control ‘widgets’ each, for applications including background music source selection, master zone level, scene recall, or microphone paging.” This was the claim I was referencing.
Further thoughts on this. If there are times that somebody mixes from the desk then probably best not to use 1 - 4 for scene changes, so they’re available.
Also, probably best to Block the soft keys from scene recall in the global filters section.
