I have an existing USB hard drive (Seagate touch and go) that appears to be a bit flaxy as a Qu-Drive on a QU-32. I suspect the problem is that the USB port needs a bit more than 500mA since when I used it on a mac, I had to use one of those bodge cables which draws power from two USB ports. Hence I used to use a powered USB hub between the HD and the mac. Can the same trick be used with a QU-32 - that is, can I use a USB hub between the mixer and the HD?
Paul
