Qu-Drive Compatibility Thread
…maybe its already there and I’m just blind, but
shouldn’t we have a sticky QuDrive Compatibility Thread to exchange experiences which devices work and which not?
On my side I successfully operated various USB HDDs and know that the SanDisk Extreme sticks will work as well.
Just received a tiny SanDisk UltraFit 64GB to experiment with, and this will hang both enumeration (if formatted with Fat32) and formatting (if I delete the partition first) on the Qu(32). Stick works well even with USB 2.0 on XP/Mac/Win7 so I guess some protocol issues (could trace it down with a USB analyzer if helpful).
Saw that V1.6 had some fixes on QuDrive, sadly my 64GB SanDisk UltraFit stick still does not work (and the desk needs a power cycle to accept my USB HDD again). Just to mention…
I’ve just acquired a USB extension cable that has the cable exit at 90 degrees to the plug, so when I plug it into the QU it will go straight off to the right, out of the way of everything. Should protect the desk and drive against accidental knocks. The phones will still be tall there, but my ST3 cable is also a right angle connector so that people brushing past, or me turning round/reaching over the desk, don’t knock into “tall” things on the desk and accidentally snap a connector…
I’ll report back on how well it works. I actually got a short USB3 lead, so the Sandisk Extreme can be velcro’d to the underside of the desk (or just left dangling, can’t decide if I could tolerate adhesive, even on the underside of the desk). Maybe I’ll use a cable clamp on one of the rack fixing points…
I bought a SanDisk UltraFit 32GB and it did not work with the QU 24 at all. A shame really as the very small profile would be ideal as it wouldn’t risk getting knocked about like the tall Extreme, in fact it could have been left in place even when putting the mixer away.
I’ve been using a 64GB Lexar S33 perfectly fine. It’s been through about a week or two of use and no dropouts yet (knock on wood).
I got it on sale for about $30, less than $0.50 a GB.
https://www.lexar.com/flash-drives/lexar-jumpdrive-s33-usb3-flash-drive?category=207
im totally new to this mixer QU-16 im picking it up wed from guitar center . first off what hard drive will work with the q drive system and dose it have to be powered . I thought I saw a video where they were demoing a hard drive but it looked like it was just usb real slim and no sing of a power cord. and maybe im in the wrong forum but I use presonus studio one 2 pro DAW cant seem to get a answer from presonus other than they don’t have time to test every mixer . I like that software and really hope its compatible with the QU-16 im buying any body have any answers . I have been using the presonus 16.0.2 mixer Thank you everybody
Great idea!
and you have started it!
we do seem to cross over and change topics so maybe the starting of these threads again will be a help for searching.
I have not had any sucess with the Sandisk ultra. I wasted so much time and money buying from different batches and also accidently buying them again…
The SanDisk I have had great sucess with is the Sandisk Ultra.
I know its chunky however I need to have certain gadgets on yellow strings etc… as have so many little bits of devices I carry around.
Andreas, can you explain what you mean by
Are you referring to initial start up, power-on like in top of the AC cycle?
Hi Buzzfry,
for Qu-Drive compatibility, you need to go to this link:
https://allen-heath.helpserve.com/Knowledgebase/Article/View/774/268/qu-drive--understanding-qu-drive-and-usb
The drive I use from that list is NOT externally powered and works great. I recorded a show a little over 2 hours in length (all 18 tracks, and no dropouts etc.) Also, for your Presonus Studio One, are you using MAC or PC? The Qu-16 works great with the Mac’s Core Audio drivers. If you’re using PC, then you’ll probably need to download & install the Windows drivers that A & H has for the QU mixer, located here: https://www.allen-heath.com/key-series/qu-series/#tab5
You’ll need to create a user account to for downloading software & firmware.
Good luck,
John
@dhak:
When I'm trying to use the small SanDisk Ultra Fit the QuDrive port completely giving up and I have to switch off/on the desk in order to get anything else recognized. Still crossing fingers that this small stick is supported in the future, in the meantime I'll also use the Extreme...
oh ya I am using a mac with the latest install of mavericks iMac 3.5 gh with 16 gig ram and a 1 tb hard drive I just ordered a Seagate plus it was on the list of drives that had been tested to work with the QU-16 I think it was 500 gb if it don’t work the worst case is it will become a time machine for my wife’s iMac. im glad that these usb thumb drives are cheep I will have to experiment with a couple . worst case with them is ill use them for my td-30 drum module for putting on my vex kits cant have enough vex kits LOL. I had downloaded the midi drivers from the website for the mac . I know im putting the cart in front of the horse I pick up my QU-16 probably weds but by then everything I have ordered will be here . I just don’t like needing something and it not be here . thanks I will let you know if my software jives with my hardware. until then its lots of reading the pfd manual and finding videos on YouTube thanks again
My USB cable is working well - just tucks the USB stick out of harms way…
Thanks Andreas, I thought that was the case.
Bob could you post a link so I can see that right angle USB adaptor?
It sounds like the thing I should invest in!
Ive noticed all of the Mac extension are sooo tight when using them?
I guess thats a fear of conectivity.
As they say in the video world… every connection looses 20%
However Ive been using 5 meter extensions to my hard drives in my studio with no problem moving 30 -40 gigs of data!
Welcome Buzzfry you sound keen as mustard.
oh well Monday morning here. Monday blues!
thank you gentlemen it’s great to have a back up group to pick your brains for info incase I get stuck best regards be back soon
I’ve been looking for it on eBay again, I’ll post when I find a current item (or I might try to hotlink the image)
I’m using this one: Left Angled USB Extension
(Also from Amazon in Germany, if available again)
Be careful with the angle, for the Qu you’ll need a left angle one, and even the pictures of those Amazon links seem to differ, they don’t. The photographed sides of the connector differ!
to answer my own question about my QU-16 working with my DAW Personus studio one pro yes it works perfect. im not to happy with the midi control its really glitchish real sluggish but I don’t need it anyway I just thought it would be cool to control the faders by the QU . im not lazy and it don’t really matter to me besides I am stoked that I can actually record the fx settings when im recording . my SL 16.0.2 wouldn’t do anything like that I would have to add the FX in the DAW . I really didn’t like the FX in the DAW .
Any new drives to add anyone, especially low profile/compact ones?
:slight_smile:
BTW… Is there any real benefit to using a USB3.0 extension cable when the QU interface is USB2.0?
Still searching for working low profile sticks myself, still no luck…
USB 3.0 cables at least have to follow tighter specs (to support higher speed). But for that small distance its probably academic only…
…and mine is blue… :wink:
I’ve had the same issue with the QU’s USB-B port connecting to the ASIO Driver under Win 8.1. Had to reboot the Qu before it would show up in the driver. I figured it would be more typical to have the QU powered up BEFORE the PC loads the driver to get it recognized.
