@Dancing Brook - as @volounteer says, the issue here is in part that the Qu won’t even recognize the drives to format them.
And this has nothing to do with the drives being too slow, as some here have suggested: in fact it is the newer, faster drives that fail more often.
Also, as I’ve pointed out above, simply finding one drive that works does NOT solve the problem, any more than finding one microphone that works would be considered adequate. A microphone input on a mixer is compatible with essentially every microphone you’ll ever run into (except a very few oddballs, such as low-output ribbon mics, that everyone knows about). Similarly, a USB connector on a digital device should be compatible with essentially every standards-compliant drive. 99%, not 1%! Even my 10 year old computers, if I plug in a USB drive, I can format it and I can write and read files - maybe not fast, but it works. The Qu is simply defective. And, as others here are noting, A&H have taken zero responsibility for fixing the problem, or even publicly acknowledging it.
The issue is backing up the mixer.
Why do we have to spend hundreds of dollars/pounds/shekels/whatever buying random USB sticks hoping they work.
Why should we have to buy an SSD drive to back up the shows/scenes/settings.
WHY DOES NOT AH CARE ENOUGH TO EVEN TELL US WHAT THE TRUTH IS AND WHAT THEY WILL DO IF ANYTHING.
@Dancing Brook
Like I said, and like @cafewalter said, the AH does NOT RECOGNIZE the USB so it can NOT format it.
We want to format it like the manual says but we are blocked by the mixer from being able to do it.
We have tried to format on other devices when it was not recognized but it is still not recognized.
Did AH try to game the USB standard to get a bit more capability and lose the ability to use USB completely?
That was what some PHB might do, I hope a real engineer would not have done that, but maybe that was what happened.
Or maybe it was the software/firmware that got changed. It would be nice if they just told us the truth.
Ok, shout out to Rodf (page 17) …or anyone.
I’m trying this drive out and it is exFAT -similar to but not exactly FAT32.
I dropped it straight onto the QU for formatting but it has stuck on the ‘reading drive’ stage.
Should I be doing it differently?
If this is like a thumb drive that also responded like this this evening, it trashed the existing format and had to be re-formatted on the PC.
Should I perhaps try FAT32 in that case?
" We bought a couple of 500GB Samsung T5 SSD drives and they have worked without errors recording 1hr30 Multitracks.
All 5 of this year’s BBC Radio Reith Lectures were done this way.
Follow up- It looks fine back on the PC and didn’t trash the drive’s format but did remove 'setup apps that were on it. Could they even apply to the QU?
my understanding that only FAT32 works and exfat will not work.
you might be able to format it as FAT32 but be sure the block size is right for the Qu as I understand some do not work.
If there is a secret article somewhere that accurately explains all of the USB mysteries I would love to see it.
Got the kingston data travellers Both models and two sizes.
Did NOT work on Qu. Says incompatible.
Post a picture of the drives you got.
Did you go straight from the package to the QU to format them?
All the Data Travelers of different models I got about a month ago
all worked perfect, went straight from the package to the mixer, formatted
and done.
They look exactly like the pictures shown in the AH image.
Smaller tjam ptjer USBs, silverish, big round hole.
Package says Kingson 16G Data Traveller SE9. And USB 2.0
I also got a 32G and a 32G SE9G2 that I will try. The G2 Says USB 3.0 and also 3.1/3.0/2.0
Will try those tomorrow.
I went straight to the Qu and it says not recognized.
Light did blink briefly then the error message. So it knows something was in the slot.
Wonder what AH thinks would be in a USB receptacle to say not recognized.
Could not format as it says they don’t exist to the Qu32.
I had read about the many others getting those to work so I special ordered them as they were readily available without hunting for something old and obsolete.
I would be amount those who say they do work and I use them all the time. Actually Data Travelers are the only USB drives I use with the exception of the Sans Disk Extreme3 for the few times I have done a multitrack recording.
OMG… All 6 of mine work perfectly. I based my 1st purchase of the Kingston a few weeks ago on the positive comments here and when it arrived and checked out, I ordered 5 more. They all work… I don’t understand why we all get such different results using the same drives…
I have tried the kingston and before sandisks of several various submodels including an extreme, and other assorted USB brands that were available easily locally off the shelf.
I would be paranoid and say the MD did something so nobody could try a USB in the device except that he could not get any to work and I finally found an old one from Staples that I gave him when it did work. I have been trying to find some more so we could consider using them for playback or recording but we cant find any that are recognized so we can format them in the Qu.
Is a mystery. I have two more of the kingstons to try. different size and one is the G2 variation on the SE9.
I never got any usb 3s to work. The only ones were the old white box Staples usb2 that I found in a drawer at home.
Are some of these formatted other than FAT32 and 32K blocks? That I have not checked yet.
If it is not that then I have to suspect the firmware version is somehow involved with this problem.
I suspect that if you ever put one of these in a win10 box they would start failing, but I never do that.
I have one USB I have just for win10 use on the rare occasion I ever turn that PC one.
Could the makers be checking them with win10 and killing them for other PCs to use?
They can be fixed but it is a pain and needless work.
Never getting another windoze box. Next time it will be Linux of some flavor.
Strongly considering changing the win10 to a dualboot with Ubuntu.
As have all of my Data Travlers since the day I got my QU about five years ago now to the very last bunch I got back in mid December and all of them in between.
I open up the package, put the USB drive in the mixer, hit format, done.
Mr. Volounteer to double check…are taking the USB stick out of the factory package and putting directly into the QU mixer and not into any computer first?
Send me the Data Traveler drives that do not work, I’m serious, I’ll even cover postage for that matter I’ll even cover the cost you spent on the drives.
I’ve used a Seagate 1TB Backup Plus (usb3, spinner) for multitrack and stereo recording. I also plug it in to my Window 10 pc to retrieve the files. It also holds the board Show backup. I haven’t reformatted in quite awhile. No problems.
@ Mike C… Like you I simply opened the new drives one by one and put them directly into the QU Drive - Format and ready to record. No computer in between.
@ Volunteer - What year is your QU mixer? I am wondering if it varies from batch to batch/ year to year.
Mine is an older one that I bought new. It has the weird glitch that some of the early models had - causes noise when recording to QU Drive with ST3 fader up.
