Qu-Drive Compatible USB Device Database
JPG files too big, I’ll try again after shrinking with PhotoShrinker app…
How do I remove my wrong entry? Line 77: SanDisk Extreme 32Gb is 100% OK!
Needs to be done by some staff member, and its a CruzerExtreme (we really need to be picky with names here).
Hi Andreas! In agree, but Holland the word “Cruzer” was not on the stick, nor the label. The internet shop called it ‘Cruzer Extreme’, confusing…
I want to use the card reader SanDisk Extreme PRO SDHC/SDXC UHS-II plus SDXC SanDisk Extreme 64GB SDXC card. Is this possible ?
Hello,
First post here.
I have a Qu-Pac since a week now. I didn’t know about that place nor about usb list compatibility. So I bought a Lexar LJDP20-64GCRBEU - JumpDrive P20 - Flash Drive - USB 3.0 - 64 Go and it seems that it doesn’t works. When I plug it, the orange light flash but steel “no USB disk present” on the screen. Did I miss something or must we add this usb key to the blacklist ?
Thanks for eventually correct my procedure.
Cheers
Ferda
Participant
Only one way to find out, just try it !
Giga
I have a Qu-Pac since a week now. I didn’t know about that place nor about usb list compatibility. So I bought a Lexar LJDP20-64GCRBEU – JumpDrive P20 – Flash Drive – USB 3.0 – 64 Go and it seems that it doesn’t works. When I plug it, the orange light flash but steel “no USB disk present” on the screen. Did I miss something or must we add this usb key to the blacklist ?
It seems you’re out of luck then :-). Go for the Sandisk Extreme, everyone seems to be succesfully using them.
Advice: spend some (a lot) of time on this forum reading about all the ins and outs of our wonderfull desks !
Giga
There has been a good bit of confusion regarding the names of the various Sandisk units. I use the 16 GB Extreme. The Extreme comes in a couple of models. The ones I use are the CZ80’s.
https://www.amazon.com/SanDisk-Extreme-SDCZ80-032G-GAM46-Everything-Stromboli/dp/B01E7OPRYS/ref=sr_1_9?ie=UTF8&qid=1488414868&sr=8-9&keywords=Sandisk+Extreme+USB+16+GB
They work.
Dang, you’re right I messed up, sorry
I tried to modify and/delete my post but it won’t let me
Giga
@Giga: Post magically corrected… :wink:
haha LOL ! Andreas you devine you :slight_smile:
Giga
I’m new to the forum and have recently started using the QU-16. I very much want to do some multi-track recording to a USB stick and have followed the working devices chart closely.
One thing that I have never seen mentioned on this thread is talk of any kind of adapter to go from USB B (male) to USB A (female). The Qu-16 usb drive port is a USB B female port - at least mine is? I should think this is absolutely required since the QU mixers have only a USB B female port and these USB sticks being mentioned are most certainly USB A male sticks.
I’m looking at something like this on Amazon:
Would this work? Can someone point me to a good adapter that he is using? Or straighten me out if I’m vastly confused… :wink:
You may be at, least a little, confused!
The USB on the front of your mixer, next to the headphone socket, is type A, and this is the one to record to a stick.
The USB on the back of the mixer is a B and is used to connect to a computer.
ARGH! Thank you! I knew it was something ridiculously simple. I haven’t had the board long enough and I feel like I’m drinking from a firehose trying to learn all that this thing can do! Anyway, thanks for taking it easy on a noob.
@Gigabytes
Thanks for advice. I’ll do it
:slight_smile:
Don’t learn it all at once…
Read the manual - take at least a week over doing so…
There is lot in there. You won’t remember it all after one read, but you might remember enough to go ‘Oh, thats in the manual’…
Really need some clarification on which scan disk extreme 3.0 32gb or 64gb you all are referencing.
Is it this
https://www.amazon.com/gp/aw/d/B00DZPUOUI/ref=mp_s_a_1_4?ie=UTF8&qid=1490577151&sr=8-4&pi=AC_SX236_SY340_QL65&keywords=sandisk+extreme+usb+64gb&dpPl=1&dpID=31t8vh8rJdL&ref=plSrch
And this
https://www.amazon.com/gp/aw/d/B01E7OPRYS/ref=mp_s_a_1_2?ie=UTF8&qid=1490577537&sr=8-2&pi=AC_SX236_SY340_QL65&keywords=sandisk+extreme+usb+32gb+2+pack&dpPl=1&dpID=41Unwg3QnfL&ref=plSrch
Or this
https://www.amazon.com/gp/aw/d/B007YXA5TC/ref=mp_s_a_1_7?ie=UTF8&qid=1490578014&sr=8-7&pi=AC_SX236_SY340_QL65&keywords=sandisk+extreme+3.0+32gb&dpPl=1&dpID=31V60BEYgvL&ref=plSrch
Or this
Amazon.com: SanDisk Extreme 128GB USB 3.0 Flash Drive Black, (SDCZ80-128G-G46) : Electronics the specs seem different on this one
This is the exact one I’m using: Amazon.com: SanDisk Extreme PRO CZ88 128GB USB 3.0 Flash Drive Speeds Up To 260MB/s- SDCZ88-128G-G46 : Electronics without one problem whatsoever…
Giga
