Thanks … Marco68
Inviato dal mio HUAWEI P8max utilizzando Tapatalk
Thanks … Marco68
Hi to all,
Hi justin
Last friday I tested the SanDisk SSD Extreme 500 Portatile 250 GB with some multitrak recordings.
After format it on the QU 24, I recorded on it in MTK mode some sessions, as First impression is very good, I had 0 errors and playback/recording without audio skipping
Model number SDSSDEXT-250G-G25
Thanks marco68
Hello, newbie here.
Going to be doing multi-track recording with the Qu-16, so I’ve gone thru this entire thread and the list of tested devices.
Ordered one of the “tested” WD hard drives.
I’m wondering something, if someone could help on how you do it, that would be great.
I keep reading that once you format the HDD, that you should only use it for Qu-drive data. I get that.
But that does not stop you from using it to transfer files to your other devices, such as plugging it into a PC or MAC, in order to edit those files in a DAW or other program, correct?
Said differently, how do you best go about transferring recorded WAV files to other devices?
Formatting the drive just wipes all data off it, configures it correctly and sets up the standard folder structure used by the mixer. Once this has been done, the drive can be used on the mixer or on your PC/Mac for transferring files to and from the desk, just make sure you leave the folder structure the same.
Jake.
thanks Jake…
Ciao Marco68 noi possiamo parlare via mail o al telefono??? Se ti fa piacere, devo sempre devo convertire inglese in italiano…
La mia mail celantegianni8@gmail.com. Saluti grazie.
what is the status of the sandisk drives now? really frustrated that the simple process of recording MTK or stereo has turned into a nightmare! I just want a drive that works. Can Allen & Heath not sell us one that thy have tested and can stand over? if not, why not. I now have a desk that I have to guess what recording device will work on it. I don’t have unlimited funds - don’t use a community list, use an A&H approved and tested list - PLEASE!
what is the recording throughput specification for the QU-32 desk - you say most USB pen drives are not suitable but why? what spec do I need on a usb device to work? I cannot keep guessing.
A definitive answer is needed - If I’ve missed it, then I apologise but this is really frustrating when it ‘should’ be a very simple task
yours in hope and frustration
Richard
This is insanely frustrating. I have a couple dozen different USB sticks, some new, some dating back many years. Exactly 1 is even recognized by my QU-32. Won’t multitrack without errors, but at least I can archive my scenes on it. It’s a SanDisk Ultra USB 3.0 64GB. In smaller type it says SDCZ48-064G. OK, I’ll get some more of those, only 32GB since all I will put on them is 300 kb of scene data. Same name, and SDCZ48-032G. Surprise, the QU-32 won’t read or format them. I preformatted them in 3 other computers first, Macs and PCs, but that made no difference.
Not all of my USB hard drives work, either. And the idea that I need to carry around a 500GB spinning disk hard drive with a cable in order to archive or transfer some 26KB scene data files just boggles me.
This is absolutely ridiculous. Every crappy computer made in the last 20 years will recognize any stick you put into it, at least well enough to format it. What is the problem? Is it hardware? OS drivers? Does the SQ share the same flaw? Fix it, please, Mssrs Allen and Heath.
Has anyone had issues with drives degrading over time? I bought three Patriot Tab 32GB USB 3.0 drives from the “good” list about a year ago. They all worked flawlessly initially, but then after a few months of use each one started to have errors crop up while recording from the qu-drive (on my Qu-Pac). I always format in the mixer after each recording…
Report to SanDisk Extreme Portable SSD (250 GB) - Model SDSSDE60-250G
I bought a SanDisk Extreme Portable SSd this week an here’s my expierience with it.
First of all: after some tricky format issues it works on a SQ-5 (Firmware v1.2.0 r2258) without any dropouts on multitrack recording!
Although it is working now, I had some trouble with formatting right in the beginning. The console won’t format the device and there was still a red exclamation mark displayed near the usb symbol at the desks touchscreen. After choosing the format option the progress bar ran to 255%!!! percent but nothing else happened and the disk was unusable at this point. I tried several things, formatted it several ways on my Win10-PC, but the SQ didn’t work with it.
By nearly giving it up (another waste of 100 € to the recording function …) I tried to copy the A&H folder structure of a working usb stick to the SanDisk SSD on my PC and unbelievable now the SQ was able to format the SSD! Since that the device is working fine! - May this would be a workaround for other similar problems?
For Rebuyers: I bought it on Amazon.de and I use it in combination with a deleyCon USB-C to USB-A cable:
SanDisk Extreme Portable SSD 250GB
deleyCON 0,5m USB-C Kabel
Regards,
Bofrost_Mann
After much research - seems the SanDisk Extreme CZ80 64GB USB 3.0 Flash Drive - SDCZ80-064G-GAM46 is a GREAT option - !!!BUT!!! they are no longer made. Any word if the updated GO versions works as well (Sandisk Extreme Go 64GB USB 3.0 (3.1 Gen 1) Type-A USB Flash Drive - SDCZ800-064G-G46)??? Please help. I am suffering like everyone else and really wish A&H would just sell a working drive.
I have a Sandisk Extreme Go 64GB USB 3.1 and it does not work at all with my QU-PAC, no chance.
I bought a “SanDisk SDSSDEXT-500G-G25 500GB Extreme 500” (Portable SSD) which works nicely so far.
Thx to those above who recommended the 250GB Sandisk SSD.
I can confirm that the Sandisk Extreme 500 250GB SSD works prefectly on a QU-SB with several hours multi-track from a festival over the weekend.
The model number is SDSSDEXT-250G.
Just wanted to report that I’ve had good luck (so far) with the Samsung T5 Portable SSD - 250GB - USB 3.1 External SSD (MU-PA250B/AM)
Certainly more expensive than a usb stick, but really reliable in my tests so far! No errors after nearly 8 hours continuous in multitrack!
Bought the highly recommended Sandisk 64GB Extreme, formatted in the Qu Drive, multi-tracked a 2.5 hour graduation ceremony, now my drive is not being recognized on any device, including the Qu-Pac I recorded on. Bummer. System was throwing a lot of errors. I didn’t have time to stop/re-start the recording.
I have a Sandisk Ultra USB3 32GB drive, it would never work on the QU16 but now seems to work fine on an SQ6
Hi All,
does anyone have a link to a list of compatible usb devices for use with SQ-drive?.
have purchased two off of the list for QU-drive devices to no avail…
thanks in advance
Hi, I recently bought a Sandisk Extreme cz80 16GB usb 3.0 drive. It work flawless on the QU16 running firmware version 1.9. I can record and playback 1 hour 40 minutes, 16 tracks + L + R.
