Qu-Drive not recording Mix output
Qu-Drive multi-track only has 18 channels, and I need to record 22 channels. So I am trying to create and record a sub-mix of certain rarely used channels. I have routed insert sends of various channels to Mix2, and selected Mix2 onto Qu-Drive channel 17. I can see activity at the output of Mix2, but Qu-Drive shows no activity on channel 17 and records nothing. What am I missing? I would be grateful for a list of settings required to record Mix output.
QU-PAC f/w 1.90
QU-PAD app 1.93
When you change Qudrive channel 17 to your mix channel, make sure you hit the “Apply” button.
You might also want to think about using a laptop and recording using the usb-b connector instead. This will allow you to record all 22, or more, channels separately.
The Apply button had been pressed, because all the channel input to Qu-Drive assignments worked as expected. It was just the Mix 2 tp Qu-Drive that did not work.
Ideally I would use a laptop, but don’t have one available right now.
Any more suggestions?
Hi Jamie,
Please start a ticket at support.allen-heath.com for further assistance with this, we can look into why it’s not working for you.
Alex
