Qu-Drive playback routing
This seems to have been asked a couple of times before, but I’ve not managed to find an answer…
Is there a way to route the multitrack playback from the Qu-drive to separate mixes simultaneously?
e.g. record a number of tracks to the Qu-drive, then when playing back from the Qu-drive to send different mixes to L&R, Mix 1, Mix 2 etc?
TIA
Exactly the same as you would make a regular mix. You only have to tell the channels of your choice to pull signal from the Qu-drive instead of from a mic.
Good luck !
Giga
