Feature Suggestion:
USB Playback input sources routable to different board inputs.
Rationale:
We can route MANY diferent sources (ch, aux, grp, LR, etc) to the USB as an input. [Record]
We CANNOT route those [Playback]
Word Vomit:
For virtual sound check or nearly any other task the Qu Drive USB 1-18 outputs needs to be routable to the channel inputs not just straight 1-18.
On Qu32 for instance recording channels 1-4,9-15,25-32 = 18 recorded channels but those channels will always play back to 1-18 board channels. We need to send those USB output channels back to their same respective input channels.
Yes, that “feature” was a big surprise and disappointment to me. I recorded the band channels hoping to play back the band and fine tune channel EQ, etc solo and with no one present. Had I known, I would have placed the band on the lower channels and other room mics on channels on the high end. I could still copy/move everything around, but I am not sure how this will affect mix outputs and Qu-you setups.
I assume that using the custom layer would not overcome the issue.
