Qu Drive question
Hi all,
I finally have a QU-PAC on the way. Should be here Tuesday. I have a question though dealing with recording. Let’s say I’m doing a benefit and have 5 to 6 acts and would like to multitrack record them all. Rather than let the recording go on for 6 hours, can I stop and save after each performance? That way I’d have smaller files to deal with when chopping the songs out individually. I wouldn’t have to worry about going over the file size for the stereo file. I could also give each group a quick stereo copy of their performance. Any other tips would be greatly appreciated.
thanks,
Rob
Yes, you can. You can configure your soft keys to stop and start the recordings too. Re the stereo copy, you can’t record multitrack and stereo using only the qu-drive at the same time. One way around it is to record 18 tracks to qu-drive, with 1-16 being individual channels and 17-18 being LR (they’re all freely assignable,) then give your acts copies of 17&18. You could also record multitrack over USB-B to a DAW, and simultaneously use qu-drive for a stereo recording. Finally, you could use qu-drive or the USB-B for your multitrack recording and route your LR to the alt-out socket, and use that to feed an analogue recorder of some description.
You can, and with different acts you’ll likely be fine - but beware that arming the recording takes time…
What Bob said but arming time much faster if using an approved usb pen rather than an hdd.
Thanks so much for the replies. I have a Sandisk Extreme 32gb on the way. Also a WD Elements 500gb HD. So if I understand right, when I stop the recording, it will finish writing the files. Then when I start it again by arming the unit and it will create another directory for the next round of multitrack files? When finished, I would have 5 or 6 different directories, one for each act. I can then use tracks 17 and 18, if set up that way, to make a stereo file, dither down to 44.1 and 16bit and put on a CD to give out?
Rob
Correct - or drop the 48K24bit files onto a CD as data…
Depends on the time you have mostly.
The stop is pretty quick, but IIRC it tries to queue the existing project automatically - when you then hit rec it “arms” the files - and this can take time…
Excellent Bob. Thanks. Can’t wait to get the Qu-PAC tomorrow and play around with it. I’m assuming all those recording functions can be set in soft keys and be done remotely?
Yup, soft keys have it covered :slight_smile:
