QU Drive - working with USB hard drive
Hello,
Need some help with managing USB hard drive and QU drive features. I just used our QU-24 for the first time live performance - worked great! I recorded the performance to USB hard drive, multi track. What do I do next? I want to transfer the files to my computer to import into PRO TOOLS, and also simply just record MP3 files to share. However, when I connect to my computer, it asks me to format the drive, if I do that - I will erase the recordings. If my computer does see the folder tree - how can I export files, add wav files I would want to play, etc. I don’t seem to find answers in the manual. Thank you very much in advance.
Can you see recorded files in the mixer?
If so then your computer should recognise the hard drive as normal drive with acces to it…
Yes, mixer has formatted the hard drive, no errors, just as in the manual, and it was recording the tracks. I did not have a chance to try playing them on mixer as of yet. I will try to maybe connecting to a different computer.
What computer? It’s failing to see a FAT system, which is daft…
So, I connected the hard drive back to QU-24, it loaded it up successfully, and found one file, QU-MT001. However, as I was trying to select it to play, I received error message “Invalid Project”. The hard drive is SEAGATE SRD00F1 - 4TB. Could the problem be that it is 4TB? I think I read somewhere that QU-24 can only take up to 2TB.
“Maximum USB drive size (FAT32 file system limit) is 2TB.” is written here:
Understanding Qu-Drive and USB Devices (no idea how you format a 4TB drive with FAT32, btw.).
Maybe the Qu could simply reject drives out of spec.
Possible to partition it smaller…
Properly addressing that large drives require a different commandset (USB Block Device Class), not sure which one is implemented in the Qu. 32 Bit LBA addressing imposes a physical limit of 2 TBytes which also affects the classic partition table.
Firstly - FAT32 is still the only disk format that is truly cross-platform compatible.
In other words it will work on whatever computer/digital device that you connect it to.
However it’s elderly and clunky and has a whole bunch of restrictions.
Windows computers will not natively format any drive larger than 32GB in FAT32.
However there are third-party applications, including A&H mixers, that will format a larger (often MUCH larger) drive in FAT32.
The absolute maximum volume (drive) size for FAT32 is 8TB and the absolute largest individual file size is 4GB.
As you head towards these limits, it’s not unusual for specific platforms to fall over long before you get to the theoretical edge.
A&H have limited FAT32 volume size to 2TB to retain integrity with delivery speed to the external drive
You MAY be able to salvage your files with drive recovery software and/or specialist help but as you have already broken the rules for the A&H platform you will have to weigh up the potential cost of this against writing off the gig to experience.
You don’t need a 4TB drive unless you’re doing Live Aid or the entire night of Comic Relief.
A&H mixers are not at all unique in demanding rigorous specifications for their streaming hard-drives.
In IT terms audio multitrack recording needs very precise and controlled constant data communication, which is actually unusual in the industry.
It’s less about data rate and more about consistency as there is a lower level of data-correction and buffering compared to most IT applications.
Sorry to rain on your parade but please use it as a learning experience and next time stick a well respected 500GB drive in the slot and fill your boots!
Just to add a little more FAT32 formatting knowledge here.
While Windows won’t format drives larger than 32GB.one of the favourite ways to quickly set up drives in FAT32 is readily available providing you have both a host Windows computer and Internet access.
Go here:
https://www.ridgecrop.demon.co.uk/index.htm
Then click the “Windows GUI version of FAT32 Format” on the left of the screen.
Your target drive will need to be already connected to the host machine.
Double/triple-check that you are targeting the correct drive before you format!
The “allocation unit size” dropdown needs to be set to “32768” which generates the correct cluster size for A&H connected drives.
It can take some time for your mixer to recognise the drive after external formatting.
Rebooting the desk with the drive already connected can speed up the process.
All of this doesn’t negate the strict requirements for streaming communication between QU mixers and drives.
From personal experience Qu-Drive drives with their own power supplies tend to work well although QU-Drive is usually happy with high data-rate memory sticks - I use Sandisk Cruzer Blade 128GB sticks unless it’s mission-critical when I plug in a Glyph GT062 2TB RAID array drive, which mirrors on the fly to two separate 1TB drives.
Usually the USB B streaming port is feeding a computer with Pro-Tools or Adobe Audition in this scenario.
As has been said, the maximum size that you can format a FAT32 disk is 2TB. Here’s why . The best thing you can do is to partition your disk under Windows into 2 x 2TB partitions and then format one of these on your QU.
I do not know if a QU can see two partitions as I do not take delivery of mine until next Monday but, I do know about disks and about Windows.
So I bought a Seagate Backup Plus Slim Portable 500GB because it’s supposedly a confirmed working hard drive. Now my qu 32 wont recognize it. I’ve tried reformatting in in NTFS, exFAT and FAT32 and no difference in result. I’m running the latest firmware (1.8). It will recognize a 4GB Sony flashdrive that I save store scenes and libraries to but it’s not big enough to record longer live multitrack sets. Another issue is that when I plug any drive in (even ones that work), they won’t read. If I power down the unit and and then plug it in and start it up while the usb is plugged in, then it will read (not with the Seagate still). Any suggestions?
Are you trying to connect via Qu-drive or via the USB-B port on the rear panel? The Seagate drive should be connected via the USB-B port.
Really? How are you supposed to to that? I’d need some kind of double female usb to convert it. I’ve looked it up in a number of places and this is the first I’m hearing about that. Can anyone else confirm this? I’m wanting to do multitrack recordings and playback and from all of my research it should be possible through the qu drive?
All you need is a USB-b cable.
It’s an external hard drive that does not connect with a regular usb. I’m not wanting to record directly to a computer. I want to record and playback via qu-drive with the external hard drive. This is the cable it comes with.
OK. I have the same cable for my Seagate 500. I use the USB-B for connecting to a Macbook for live streaming and mis-remembered things. Sorry.
You might be out of luck with that USB 3.0 drive. During a quick internet search for a USB 3.0 to USB-B cable I discovered that there are specialty cables for that but the USB-B portion of the cable in question is a different configuration than a standard USB-B connector. I don’t think it will work. You might want to use that drive as a backup for your home computer and just get another drive.
For live multitrack recordings on my QU 16 I use a 64Gb USB 3.0 stick in the Qu Drive that will hold hours of recordings.
