Qu family no more updates?
The HPF and LPF options on all outputs would be good for speaker control - one more box which can be left at home for a medium sized gig.
Yes, one less box to bring, but that speaker management box includes more than just HPF/LPF and you’d be leaving all that behind as well.
Building loudspeaker DSP into the console might be minimally handy, but it’s not really the right place to do it. That processing should be associated with the speakers, not the mixer. I much prefer any “upgrades” to be focused on issues which enhance mixing capability/function before addressing larger system management issues.
Dick. Since the QU series already has about 2/3 of speaker management on board. GEQ and Comp it’s unimageable why LPF was never added. The knob and button already there. Can’t believe they have no DSP left to add that. Especially for monitor mixes. I’m more amazed as to why no one has ever commented from the factory either way.
George…
If you’re going to do speaker management, I believe “more is better” and a designated managemnt system/box far superior to the tools available in the existing Qu.
  1. Proper crossover filters and CHOICE of slopes.
  2. Both HP and LP filters.
  3. EFFECTIVE limting for protection. You can’t expect to set up the Qu comp as a limiter and catch damaging transients. Plus there’s the real and present danger of compression raising the RMS level delivered to the speaker causing heat failure.
  4. Driver alignment delay.
  5. More.
Yes, it would be handy to have X-over and HPF/LPF ready to go. Would it really allow you to “leave one box at home”? It depends…
If we’re to consider simple modifications of existing features, my votes are still for “expanding” the gates to include the choice of downward expansion, using EQ for frequency sensitive insertable triggering and/or multi-band compression. I miss my DBX DDP and my TCE Triple-C’s.
I’m also not keen to see much more speaker processing in the desk - more to get wrong. HPF would be good though.
Anyway my PA systems do not always get used with a QU, or even with my own desks. So I’d need the speaker processing units I use anyway. Similarly, my QUs sometimes run to other speaker systems. So it makes much more sense to keep speaker management/crossovers etc with the speakers.
Maybe for larger desks with expansion ports, an optional card would work (think a Lake card was available for a mixer I used at one time).
I was in error. I meant HPF not LPF. I really don’t care about xovers. Just adding HPF would be enough.
Given possible CPU limits even allowing the peq to have a H/L PF would be useful, it’s not often needed, but it would be better than a 15dBb shelf
I just hope that they won’t forget us and they will give us an update for all those things that requires to be better…
I feel if they aren’t forthcoming soon with something that the next brand that has the latest coolest new board will reap from lots of folks jumping ship.
Meh, the board is still pretty darned good.
It’s not as if I need more features…
Digital capacity has us all slightly spoiled in many ways, and I still think that a dedicated control surface to control the SB/PAC (or any of the range really) over Ethernet would be a major addition. Even if it is (QU wise) short on faders. Although at that point a scribble strip makes sense…
but new hardware is the place for that!
IIRC, the StudioLive had (or has) insert points pre-A/D conversion allowing the use of your favorite old outboard.
BAM, my reasoning exactly. the eq shelf is being used on ALL my monitor mixes, but i find the HPF would probably perform better. Who DOESN’T cut lows to monitor wedges but needs it to pass on to the mains? Seems pretty standard to me. PLEASE UPDATE THE USB DRIVE to accept more. Everything else I can easily overlook. Scribble strips would be nice, but isnt that a big draw to upgrade the the GLD? There’s a price point issue, lets not forget :slight_smile:
I love and IMHO, we should all love the QU series. The digital revolution is amazing. Racks of equipment in a small box.
I started with. Qu-16 and now also have a Qu-Pac in a small box with a DriveRack. I have enough equipment to setup and run a to run a ton of shows quickly and easily. With Qu-Pad I can wander around stage and make it beautiful for the performers and can then sit in the audience and help them enjoy a great show from a single seat. No need for a board and racks full of equipment in the back of the house or back stage. I can have someone on stage with an iPad for monitors if I want (added after I bought) and I can let the performers control their mix (also added). It is incredible.
That said, I’d love to see some software upgrades, and remain hopeful as they are still selling the series so they need to compete. I’m hopeful we will be thrilled with a 2.0 release soon, based in part on our feature requests, accepting the limitations of the hardware.
I read on a post on A&H’s SQ mixer announcement over at Facebook the QU range is still under development and there is a new update coming!
Things I’d love to see are :-
-Spectrograph of QU-PAD
-RTA overlaid on PEQ + GEQ
-DeEsser
-Customisable channel colours
The RTA overlaid on the EQ pages is top of my list of things I’d love to see on the QU range. Also it makes sense to have Spectrograph on QU-PAD for people using QU-SB and QU-PAC mixers. Any of the other features would be a welcome addition.
That would be nice but it’s been nearly a year and a half so I don’t think it’s likely.
Top for me would be crossovers on the mix outs.
“I read on a post on A&H’s SQ mixer announcement over at Facebook the QU range is still under development and there is a new update coming!”
Well that got me searching! Here’s what I found:
“…There are no planned release dates at the moment, but it won’t be months away. Cheers!..”
and
“…there are no hardware updates planned for Qu at present, but as Qu is digital, the firmware/software side of things is still in active development. Thanks…”
The catch with this is that the Qu32 is a big seller. My biggest. With an SQ6 you only have 24 onboard preamps so you need at minimum an 084 to get up to what a Qu32 has plus 1/4” line inputs. All for not quite twice the price. For churches and schools etc QU is a perfect fit. They care less about 96k, scribble strips or deep processing. They can barely operate what’s there. Their big thing is recall. That said there is a place for it. I like the looks and shape. More like a traditional look. I do hope to interest some folks in it. But for me it’s a hard sell against a QU.
