I have successfully installed the MixPads for the SQ7, CQ20b, and SQ4me, etc. on my iPad. I am installing a Qu7 with the latest firmware, 1.20.
I downloaded the latest .ZIP file for the MixPad for the Qu7 to the iPad and uncompressed it.
The resulting file is named “Qu-MixPad 1.2.0 AppleSilicon.dmg”
When I tap on it The name of the file shows up in the middle of the screen but nothing else happens.
I’m no Apple expert, but I have never had any issues installing A&H applications before.
Open to suggestions. It’s an older iPad Air, 7th generation, model number MW792LL/A, old enough to have an earplug port on it.
iPadOS 18.7.11
Did you download from the A&H website? Presume so based on how you phrased it.
.dmg files are the install files for MacOS.
I believe .ipa files are the install files for iOS.
If so, then that app is the MacOS version only.
You would need to download/install from the App Store.
You are exactly right, I downloaded it from the web site, not the App store, thanks!
The way I updated my Qu-5 was to update the iPad app then connect the app to the mixer. When I went to the Church after the update was available, my iPad Air 5 connected to the building network, same as the mixer. When I opened the app, it mentioned the update for the mixer was available. Go through the process to OK it and the mixer updated to 1.2 via the Internet.
My Qu7 updated just fine from a USB drive with the new firmware in the root, no problems.
