Hello,
I do not understand how scenes work.
I would like to have a scene that I can recall every time as a starting point, and then another for a specific show, with
a different custom layer.
I created two scenes with different custom layers, but when I recall one scenes, the custom layer is still the one of the scene before. How can I make the custom layers follow the scenes?
Thank you
Per p66 of the Qu Series Reference Guide:
Custom Layer assignment is stored in scenes. They are blocked from Scene recall by default. If you want these settings overwritten when scenes are recalled then unblock the ‘Custom Layer’ item in the Global Filter. Use the Scenes / Global Filter screen.
I did that but is still not working
Have you reduced the scenes so that the faders are actually saved correctly?
hi, what do you mean by “reduce the scenes”?
thanks
