Qu-Pad can't control soft keys
I have mute groups assigned on my QU
QU into a wireless router
iPad 3 using WiFi
Nothing else is on the network, just those two things
Everything works perfect from QU to iPad, except it will not control Soft Keys
Regular mute’s, PAFL’s, all faders and buttons work flawless
It’s only the soft keys 1-4 that don’t respond either way (hit on QU, doesn’t show on iPad, hit on iPad doesn’t show on QU)
Soft keys aren’t displayed on the QuPad.
Mute groups work fine on mine, I tend to have all four on one strip on a custom layer - are they assigned to your soft keys?
Yes, they won’t work for my mute groups for some reason. Both ways does nothing
Where are you checking the mute groups on the Qu from? A sure place to check them is on the Home screen. Softkeys can be unassigned.
Read the manual. Try again.
If you follow the instructions, it WILL work, but you still won’t find any soft key control access from the Qu-pad app. It’s not there.
Remember you have to select the function for the soft key AND assign channels to the mute group. You mute a group on the iPad from a Mute Group channel strip placed in one of the custom layers or by selecting “Mute Group” in the selection strip on the left side of the Qu-pad app on your iPad.
If you’ve selected Mute Group as the function of your soft key and populated that Group with the desired channels you should be all set. You can activate the muting in several locations after this:
Soft Key
Console touch screen
iPad Mute Group
iPad Custom layer Mute group channel strip
Good luck. You’ll figure it out…
