Qu-Pad: difficult to grab unset setting "points"
When using the Qu-Pad it is sometimes difficult to be able to grab the small circles or dots you use to show for example the freq and gain of the PEQ, or the ratio of the comp, or the threshold of the gate. If the respective parameters hasn’t been already set in the mixer, grabbing those dots from the border of the respective frame in the Qu-Pad can be very tricky, even for thin fingers.
Maybe you can do something about it.
Thanks in advance.
Yes,
One way I find is to do a reset…
Then the points are spread out more…
