Qu-Pad shows no signal
I had this working where I could see and hear signal. I’m testing channel 16 with a condenser. 48v is red. 30 dB gain and nada. I am still learning the Qu-Pad; only recently got it, but I’ve been through so much of its aspects that I am mystified why there’s no signal going in , when I clearly had it a few hours ago.
Could you have accidentally hit the “on” button on the channel, thus turning it off?
Thanks BRS. No, I checked that. Even if I hadn’t, wouldn’t the channel react to signal coming in? …and for the record, I swapped out the mic, then the cable, so to rule those out…
did you switched the input to USB?
thanks Steffen R. Ch.16 input source is “Local” (red) and USB B (blue). My understanding is that “local” identifies my Qu-SB XLR in on that channel and “USB B” …<-the out to my iMac?
Did you try another channel?
Try a dynamic mic.
If you PFL the channel do you get anything in the headphones?
Is that channel assigned to a DCA group and or to an audio group that is turned down?
Pre amp source menu to local (red) is correct.
The USB (blue) is to playback audio tracks bringing them in through
the USB B jack.
Hi Mikie, thanks. Yes, I tried ch.14 also, plus swapped in a dynamic, to no avail. No surprise that PFL (assuming that is what PAFL is in this land) yields no sound in headphones, and no lights in Qu-Pad.
Thanks for clarifying the USB B; I was going to submit a seperate thread on this but, I’ll jot it here: I also lost my ability to playback audio from Logic. I was using ch.31-32, assigned it out in Logic prefs, see Logic’s stereo out lighting with playback, but zilch signal through Qu-Pad, when I had that hours ago as well.
On the pre amp screen do you see any meter level?
And to double check, your plugging directly into the back of the QU SB?
Maybe do a full mixer re-set, do you have any scenes saved, if you do a reset
you will want to copy scenes that you want to keep off to a USB stick.
Hi Mike. Thanks, that’s an excellent question, as I am not clear what the pre-amp screen is; I’m aware of how to navigate each channel’s processing, but in that area, pre-amp is not apparent.
The pre amp screen/menu is where you adjust the input gain and select the input source.
Do you by chance have the channel insert turned on? That’s in the pre amp menu, for the sake of testing keep it turned off.
Yes, I thought that’s the pre-amp, just isn’t labelled as “pre-amp”, so I wasn’t sure if I had elsewhere to search.
Insert is gray; toggle’s on “FX”
thanks
Is it possible your iPad isn’t connected ? Or maybe tou accidentally turned on the gate which is too tight ?
Good luck !
Giga
Along those same lines any chance your in the demo mode on the APP?
If you go into to the set up menu, audio tab, signal generator can you send
pink noise to any of the outputs, do you see that on the output meters, can you
PAFL the output master and hear that in the headphones?
Have you tried a firmware reload and or a full hard reset?
Thanks, Giga, but my iPad is connected via WiFi router and CAT5 to the Qu-16 Network. I also do not witness any disconnection.
Thank you Mike C., but my iPad is connected, plus to clear, upon further testing I discover that leaving the studio overnight “heals” everything back to functional …until… a static “pop” kills -either- the sound and its corresponding lights that are active in Qu-Pad -or- only the sound: perhaps the first time that this happened, Qu-Pad lights will still actively reacting.
It’s as if the Qu-SB becomes to hot after several minutes, (it’s not) then mutes itself after an electrical “pop”.
I hope to hear back from USA Tech Support tomorrow. This will not do.
Thanks , again!
With your iPad connected to the routers WIFI, when you open the QU Pad mix APP does
QU SB show up in the white box in the center of the screen.
On the router what port do you the mixer plugged into, it should be in one of the LAN ports (usually four of them together in a row) and not plugged into the WAN port (sometimes a different color jack and away the from the other jacks.
On the mixer the plug into the network jack not the D Snake jack.
It looks like your were responding as I was typing this post.
I am very grateful for your attention. Thanks.
Yes, when I open the QU-Pad mix APP, the QU-SB is an option. I choose it, plus does not appear to disconnect.
On the router it’s plugged into one of the LAN ports, yes.
On the mixer the plug is indeed into the network jack, not the dSnake jack.
attached is an mp3 of the noise emitted from the Qu-SB that preceded is current behaviour of randomly ceasing audio (i.e., monitoring audio)
I’m starting to think it’s more of a hardware issue.
Hard you tried a hard reset and firmware reinstall?
Hi Mike. Thanks. Indeed I have tried hard reset (unplugging), and several Network/Factory rests, which are often dysfunctional: lights do not always signal after reset button is pressed.
It occurred to me to try a firmware reinstall but once I asserted that weeks ago I had already installed the latest firmware, I assumed that firmware wasn’t the problem, but… now that you suspect that it could be, i’ll see that through …stay tuned…
