Is it possible to route the QU-16 Alt out connections to the AR2412 dSNAKE outputs?
Purpose: connect the FOH active subs to de AR2412 and control the settings of the subs.
Thanks en best regards, Luc
Hi drmoon,
The outputs on the AR2412 and the Alt out on the Qu-16 itself are ‘destination points’ for patching mixes to, so no, it’s not possible to route one to the other.
Also, the Alt Out level control only affects the local output on the Qu (rather than being a digital control for remote outputs).
To send to remote sockets (eg. feeding subs) and have control at the Qu, you can use one of the aux/mix outputs
Hope this helps explain it.
Cheers!
Keith,thanks for the quick and adequate response.
I have mix7/8 unused and will use them for the sub’s.
Now I can assign which input channels and level are passed to the subs. In addition, I can tweak delay, compression and EQ.
Remember that the acoustic cross-over point between the subs and tops will vary in accordance with any change in level sent to the subs relative to the level sent to the tops. This can greatly effect EQ and other parameters in that critical area.
