Qu sb affects to mixes
Hi all!
We have a qusb mixer installed and are using fx send to perfect the audio.
The fx applied auto is outputted to the speakers perfectly.
We have one mix output dedicated for streaming via the blackmagic atem mini.
The sound I get from the atem is completely flat and does not have any fx applied.
My understanding was the fx send to the input channels and the mix output should all be receiving the audio with effects. Is there a way to send fx to certain mix outputs?
Easy to do…think of the FX returns just like any other input channel.
Select your live stream mix, that puts all the faders into sends on fader mode, then
go to the FX returns, they will also be in the sends on fader mode, just bring up the faders to the level you want the FX to be on the live stream mix.
Check that the FX return is assigned to the streaming mix and that it is in post fade, I assume all the channels are set post fade for the live stream mix.
