QU-SB as DAW Interface
Quick Question as I’m fairly new to this whole DAW thing…
If I connect the QU-SB up to my 2013 macbook Pro running Logic Pro X what exactly will I be able to control on the QU-SB?
As I understand it, the QU-SB USB output is fully compatible with HUI protocals, etc.
Is it a case of using the QU=App via wifi in conjunction with the tethered laptop or doesn’t it work like that.
Can the QU-SB essentially replace the traditional soundcard used for DAW recording. If it does, then it is great as it will mostly reside at home but means it can be taken out into the wild of live performance/recording. Am I over simplifying things here?
Andy
