Qu sb Aux 1 pre EQ
At the risk of embarrassing myself on a public forum, can anyone point me in the direction of making Aux 1 on the Qu Pad post EQ? Aux 2 is and I am guessing that 3, 4, 5, 6 etc are but 1 is not. I cannot seem to track down the command to change that. HPFing things has no effect in the monitor driven by Aux 1 even though it does in FOH. Sorry if this has been asked before, I could not find it and I have tried to read the manual, honest.
TIA
Select a mix and go to the routing screen, there you have a selection for the “Channel Source”.
Its described with more detail in chapter 9.9 in The Manual.
As Andreas said; tap the little arrow to the right below “tap to name”.
Also, don’t forget you have 2 eq’s per aux/mix available to hone your wedges’ tone.
Good luck !
Giga
Thanks both of you. I knew it was there, I just could not find it!
