In Qu-SB there’s 4 mono and 3 stereo mix outputs. Would be nice to link/unlink the outputs as you like, for 5 IEMs or 10 wedges for example(or anything in between)…I wonder if the current mix configuration is software controlled, or is the circuit board designed in a way, which makes it impossible to split the stereo outs/link monos to stereo…
You can turn the groups into more stereo outputs, though you’d need one of the D Snake boxes to make use of them on the SB or Pac.
Yup, I might buy a AB168 at some point, but still adding this feature to the software would make the setup more flexible…
